Can anyone identify this mower please
9 posts / 0 new
Messorestore
Messorestore's picture
Last seen: 1 hour 1 min ago
I wondered if anyone can identify which model this kickstart Greens mower is. Thanks
Last seen: 9 hours 42 min ago
I believe its a Greens Master
I believe its a Greens Master Lightweight assume 14in, certainly well advertised from 1950 through the mid fifties.
Messorestore
Thanks Clive. It is 14 inch
Thanks Clive. It is 14 inch cut. However if that is a Master lightweight can you  tell me what this one of mine is ? 14 inch also. Thanks
Adrian
Last seen: 59 min 52 sec ago
That squint tank looks very
That squint tank looks very bodged - I'm waiting for you to tell me its original now, but it looks very odd. It also looks very like a Qualcast 16 - I wonder if someone peeked over Qualcast's fence?
Sean, looks to be same model,
Sean, looks to be same model, first one may be missing the cover.
Adrian, Tank appears to be original.
1954 ad below.....
Messorestore
I know exactly what you mean
I know exactly what you mean about the tank but given that both mowers have almost the same tank and both are Greens mowers I am fairly confident that the tanks are original. That still leaves the exact identification of both mowers in question.
Found the missing cover Sean,
Found the missing cover Sean, bottom left in Thomas Greens Assembly Shop- Leeds, where you can see a few hundred 14in Master Lightweights being put together.
Will send you a clean copy of the image.
Adrian
Ah, looks as though the one
Ah, looks as though the one in the first photo has had a knock at some point!
Messorestore
Thanks Clive, yes it was the
Thanks Clive, yes it was the cover that threw me. They are indeed the same mower. Oh well I've got a spare now if anyone's interested.
