Estimates on the weight of this roller please..
8 posts / 0 new
Chris G
Chris G's picture
I am watching, as they say, this roller on ebay.
If I get it, it will be a solo pickup and take out of the boot of a hatch back car. I will be armed with scaffold boards and optimism. I can dead lift a Ransomes 18 in/out of a car but I am guessing this might be fair bit heavier? With reference to the background in the pic, anyone hazard a guess? - I know there's a crack that  need to repair.
Last seen: 3 hours 36 min ago
I would guess well over twice
I would guess well over twice the weight of a Marquis and far more difficult to load without injury. Also. if said hatchback has a lipped boot, almost impossible to get out!!
mikehpw1
Last seen: 1 day 17 hours ago
Morning
Morning
Please dont even think about it  !!! I sent two people to collect one like this and there were two guys there and four couldn't lift it. I dismantled it on site and even then one half of roller was more than one person should be lifting.  And the counter balance weight  in the centre is even heavier!!! I would guess total around 150-170kg. As wristpin says two or three of you might get it up some very very strong planks that would need to be longer then your car but you would never get it out again if there's a lip on the boot. Please don't try, hire a low trailer, long planks and at least two people.
Messorestore
Messorestore's picture
Last seen: 1 day 5 hours ago
Hi, don't want to put you off
Hi, don't want to put you off but not only will it be almost impossible to bring back in a car but the crack on the roller looks pretty bad ( probably been dropped getting it out of a hatchback) Of course you can weld it but to be honest rollers are plentiful and there are much better ones out there. All said if it's very very cheap it may be worth it.
Chris G
Chris G's picture
Thanks for this guys, clearly
Thanks for this guys, clearly a 2-3 man job then, recently got rid of a Renault traffic which would have made life a lot easier.
Plan B was to make a low wooden horse in line height with the boot, board on top, lift onto board and push in. That sounds optimistic now too, so a rethink based on feedback above. Have a few supine males laying around here but I was hoping to avoid the moaning on the way to collect..
Re the crack, any ideas if that would be an iron or steel roller?
mikehpw1
I agree, I assumed to buy
I agree, I assumed to buy something with that sort of damage you must be an expert welder , if not that crack could turn into several before you're done. Find a good one would also be my advice.
Messorestore
I agree with MikeHpw1 the
I agree with MikeHpw1 the crack could turn into several. It is cast iron which can be welded but you need to be an expert welder and the rods needed are so expensive now which might make it uneconomic. As I said they are plentiful and there are some really nice ones out there if you are patient.
hdtrust
Last seen: 2 hours 39 min ago
Hi
Hi
No beating around the bush,that is a 1CWT roller, best of luck with your double hernia!
You need a van or a trailer,or if you are clever leave for some bugger else
Kind regards
Mr Wallingfield
