Help needed...Atco lightweight 12” 1947
1 post / 0 new
Martin1972
Last seen: 3 days 22 hours ago
Hello all,
I’m currently in the midst of a full nut & bolt restoration on the above mower.
i have literally got to these last two nuts which yo see in the attached image.
my issue is that I don’t appear to be able to loosen them to get them off.
as you can see, the lower right corner one which is the rear roller dive side, I cannot get it free no matter what I do.
i also have the same issue with the top nut which retains the cone clutch assembly.
has anyone got any ideas at all?
Any help will be much appreciated.
regards
martin
