Rear roller colour
9 posts / 0 new
Lee Smallwood
Last seen: 1 day 16 hours ago
Rear roller colour
I have rescued a few mowers now, taken apart cleaned, replaced bits and pieces and obviously painted relevant colours on framework and cutting cylinder, handles etc, 90% of the time the rear roller contact surface is rusty and bears no significant colour, so my query, would the manufacturers back in the day have painted them the same colour as the mower? Ive painted quite a few silver, and recently after seeing other restorations, done them black. Can I ask if anyone has a personal preference, and ill go with the majority.  Cheers to you all. Lee
Warpa
Last seen: 1 month 1 week ago
Most I see restored and from
Most I see restored and from factory are green and I've no idea why as it wouldn't last a season with paint from those days being pushed down paths etc.
The inside of the roller looks fine green, and the mower I'm working on I'll do green as it's meant to be. If it's done in silver the paint still wont last. If the roller didnt rust I'd leave natural after wire brushing for my personal preference.
Last seen: 4 hours 20 min ago
My personal preference is to
My personal preference is to leave unpainted, but clean any rust & a bit of treatment to protect from further  rust, sometimes we use black  wax for those on display.
Last seen: 2 hours 53 min ago
As I give my preserved
As I give my preserved machines some use l don’t paint the rolling surface of the roller. Iron and steel rollers get a good wire brushing followed by an application of a rust converter  which leaves a Matt black finish which wears well and looks “natural”.  Alloy rollers such as those on Auto Certes get a light rub over with medium wire wool and are left to age naturally.
RansomesRob
Last seen: 3 hours 48 min ago
Hi Wristpin. Recently bought
Hi Wristpin. Recently bought some Owatrol for my Push  mowers to try. Not used it yet. Is  this something you have used?  If so, any tips please? Thanks. Rob
I use it thinned for
I use it thinned for rustorations that are never going to see paint, as a holding preservative on cutting cylinders that have been through the stripping and derusting tanks and are awaiting the right conditions for painting  and as a brush painting additive to improve paint flow and with a decent brush eliminate brush marks.
RansomesRob
Thanks for the info Wristpin.
Thanks for the info Wristpin. Much appreciated. Rob
Lee Smallwood
That's interesting, which
That's interesting, which rust converter leaves a Matt black finish Angus? I'd prefer to use something like that than paint.
Spencer Coatings Konvertex
Spencer Coatings Konvertex gives the consistently blacker finish. Kurust tends to produce a slightly purple finish.
What  ever you use there must be an even coat of rust for it to convert. Over wire brushing leaving bare metal is counter productive as the converter will not cure on bare steel or iron.
