Stanley Bridges
8 posts / 0 new
Lee Smallwood
Last seen: 15 hours 56 min ago
Stanley Bridges
Hi. Recently added to my collection is a very strange (guessing early 60s) 12 inch electric rotary mower made by Stanley Bridges. Not alot can be found online regarding the mower although the company was producing tools and electrical equipment from the early 60s. It has an early three pin plug on it and everything seems to be there and in good order. The circular blade carrier has slots for 4 blades although only two are on the mower at the moment, it may have been supplied with two and others could have been purchased at extra cost for a finer cut, due to the size and the era, It may have been advertised as a mower for the ladies, or possibly a graveyard mower . Interesting little thing and not many around from what I can gather. I'll rewire it and see if the motor works. I'll be grateful if anyone could share some light.
Lee Smallwood
(No subject)
Lee Smallwood
Lawnmaster label
Lawnmaster label
Last seen: 3 hours 52 min ago
If is anything like the early
If is anything like the early Black and Decker mowers, it will be an electric drill without an handle under that cover. It will be a small domestic mower, there were a few about, B&D, Qualcast rota-mini etc. It was also probably only meant to be fitted with two blades at once, any more would probably overload the motor.
Lee Smallwood
I'll post more photos when
I'll post more photos when dismantling. Makes sense with the two blade thing if it's only a small motor under there. I'll get to it soon. Other projects in the "finish me pile" to see to first.
Last seen: 3 hours 43 sec ago
Bridges ( without the Stanley
Bridges ( without the Stanley) were quite a big player in the early days of DIY power tools. Something in the recesses of my mind says that they were made in South London - maybe Battersea
EDIT
Nearly right! should have googled it.
https://www.gracesguide.co.uk/S._N._Bridges_and_Co
Lee Smallwood
Yes WP, Battersea is right,
Yes WP, Battersea is right, found the graces guide on the company yesterday. Drills, routers and other power tools along with electrical components they produced, I cannot find any link through various websites regarding gardening equipment they made.
Last seen: 12 hours 38 min ago
Hi Lee
Hi Lee
This is a 1960 ad, as you can see this one was simply an attachment for your drill, I do have the rotary hoe & hedge trimmer,always on the look out for the grass cutter.
I assume yours is slightly later than the onw in the ad, I have volumes of gardening mags covering this period & will try & find your model when i have a few mins.
Cheers for now
Clive
