Which Decal?
Hello all
i have recently acquired this little beauty it’s all complete and original & it works!!!
not too shabby for something that’s over 70 years old.
i plan to fully restore it but wasn’t too sure of which decal coat of arms to use as the current one is almost none existent.
either King George or Queen Lizzy?
can anyone advise the correct one to use?
regards
martin
Clive1997 Sat, 20/04/2019
Hello
Is there a small brass tag on one iof the bolts on side panel I think the right as you stand behind, if so it may give year.?
Martin1972 Sat, 20/04/2019
Hello
yes, the brass tag reads 1247
thank you
Thank you for the info.
your help in the matter is much appreciated.
regards
martin
gtc Sun, 21/04/2019
1247 indicates 12 inch cut, manufactured in 1947. You're fortunate that the plate is still in place. Many get torn off in the heat of battle. That mower appears to have been well looked after. Lots of Atcos that I come across end up in the back of the shed when the ignition coil fails. The other common issue is a broken kickstarter spring.
I like the 12 inchers because they are easy to lift into and out of trailers.
This guy sells Atco decals: https://www.ebay.com.au/itm/ATCO-Vintage-Mower-GEORGE-VI-Coat-of-Arms-R…
Martin1972 Sun, 21/04/2019
Hello
thank you for the information & the link to the decal.
i appreciate your help in the matter.
regards
martin
OLC Shop Sun, 21/04/2019
It might be worth pointing out that the the Club Shop supplies a very good range of decals or transfers, currently over 70. If you refer to the Transfers section on the website you can view the range.  We currently have in stock the correct ones for this machine; you might like to email me direct for more details. - colin.stone@oldlawnmowerclub.co.uk
Martin1972 Sun, 12/05/2019
Hi
apologies I have only just replied I have recently been away on hols and just back yesterday I have sent you a direct email regarding your reply.
regards
martin
