Dennis 24 inch cut mower
11 posts / 0 new
Hoover
Last seen: 3 weeks 6 days ago
I've just acquired a Dennis lawn mower with seat roller.
Is their any resources regarding dating? Plate on the side  says 273 Z and the seat is a spring assembly with wooden sides.
villiers98
I seem to recall someone here
I seem to recall someone here has knowledge re dates .
A photo or 2 always helps
Bit of general info on dennisuk.com. If its the model with the 2 clutch levers and started by handle they are real quality
Hoover
It's exactly the same as in
It's exactly the same as in the advert and yes it does have the two clutch levers with the Dennis name picked out in gold with a black surround
Hoover
All the other bits are in the
All the other bits are in the shed at the moment but seem to be all there. It's a round tank one
villiers98
That looks very good and
That looks very good and original . With the remains of the pin stripes remaining I would just oil the paintwork .The engines are lovely with a unique sound. I hope you have a decent lawn for it
villiers98
Hoover
I was going to varnish the
I was going to varnish the remaining paintwork to help protect it. I'm also going to build a lean to help keep the weather off
Online
Last seen: 2 min 44 sec ago
Perhaps a paintwork expert
Perhaps a paintwork expert will advise re whether varnish is the way to go and if so, what varnish. I would be worried  that the varnish itself  might deteriorate to the detriment of the nice original paint.
The machine certainly deserves a weather proof enclosure but are you aware that there is provision to reposition the grass box to cover the engine?  Unless your enclosure is nice and dry it may be wise to remove the magneto for the winter and keep it indoors; in the airing cupboard with the welding rods is a good hibernation spot!
suzanne shaw
Last seen: 11 hours 36 min ago
I use Owatrol to protect
I use Owatrol to protect machinery. Seems to work for me and gives a little lustre to the paintwork.
Online
Owarrol is undoubtedly good
Owarrol is undoubtedly good for certain applications, I use it as a non stick surface for cutting cylinder blades and throw plates but a bit too glossy for a machine like this Dennis.  IMO the oily rag is the way to go.
Hoover
I have been using the grass
I have been using the grass box as a cover and I'll check out the product you recommend as I want to keep the paint as original as possible
