Suffolks of the 50s & 60s
9 posts / 0 new
Last seen: 1 hour 4 min ago
Left to right.
Colt, Series 1 Punch, Series II Punch, 2 x MK VII Punches, Punch 17" Professional.
One MK VII complete with grass box is for sale or swap with a complete Series IV or V Punch with grass box .
The MK VII is a good useable and reliable classic fully overhauled and sharpened.
hillsider
hillsider's picture
Last seen: 16 hours 19 min ago
They look really good, you
They look really good, you only need one more and you have one for each day of the week.
There is but it was
There is but it was inaccessible for the picture!
Hainesjw
Last seen: 2 months 5 days ago
I've noticed my mower has the
I've noticed my mower has the fuel tank mounted midway up on the handle, would this mean it's not part of the punch family? I'm in Aus btw
May be but if you can post an
May be but if you can post an image we can identify it - hopefully.
Hainesjw
Here it is hopefully the pic
Here it is hopefully the pic uploads ok
I'm thinking that your
I'm thinking that your machine would originally have had the fuel tank mounted on the top of the engine  cowling. If your cowling has two captive nut holes above the coil starter and one on the horizontal surface between the recoil side and the cut out for the spark plug it will confirm the original position. However there is also the possibility that the cowling has been changed for one that never had a tank mounting.
Back in the day there was a tendency for people to grasp the tank to pick up the machine straining the spot welds holding the tank bracket to the base of the tank and causing it to leak so that may be the reason for the swap on your machine. Faced with 'this problem we would seam brazen right round the bracket which would seal the leak and prevent further failure. On later tanks the manufacturer did the same.
It may  be of interest that the above image that I picked at random from my " library" is of the Professional version of the 17" Super Punch which differs from the standard machine in the following areas.
Solid steel front roller.
Eccentric adjusters for fine alignment of the cutter unit in the chassis.
Ten bladed cylinder
Heavy plain rear rollers
Drip tray under the carburettor to prevent fuel burns on fine turf.
Hainesjw
Yeah I see on the engine
Yeah I see on the engine cowling it does have provisions for a fuel tank to be mounted.
I had another Suffolk with the same set up (tank on the handle) but the cowling didn't have fixing points for a tank on the motor and it was originally green. Did they ever have different colour schemes for these mowers?
The same engine was used on
The same engine was used on Suffolks, Atco and Qualcast. Suffolks were red / orange , Atcos dark green and Qualcasts a lighter green.
