2001 Suffolk punch 14s petrol - drive problems
2 posts / 0 new
Videoman
Last seen: 1 week 6 days ago
Hello,
I am a new member to the club and I have a couple of old mowers to renovate (or try to in the future!!) but I would appreciate some advice on a relative new machine,’a 2001 Suffolk punch 14s petrol cylinder mower QX system’, this is a 2 rubber belt driven-machine.
The engine seems to run perfectly- but I seem to have lost the drive completely with the roller locking up as well both forward and reverse!, - but the cutters seem to operate ok.
I did fit a new pinion drive and replaced the 2 belts but that didn’t last long so I have resigned myself to taking the roller off – which I now have done to replace the drive shaft and plastic bushes/housings which are held in with 3/16” pop rivets (I think). The carrier bearing/housing for the pinion shows some slight wear but 2 of the 3 screw shoulders of the carrier are broken off. Also the large belt pulley that turns the roller the centre is cracked too
The parts I think I need are:-
2 X roller bushes
1 X roller shaft/spindle
1 X pinion gear/drive
1 X pinion carrier and bush
1 X belt pully or centre replacement,
Any help in sourcing these items would be appreciated, also any advice or other parts that I may need your input would be most helpful.
Thanks in anticipation
Keith.
PS. I did read an article on the technical forum dated-10/4/2018 from Tristan, - wristpin provided some valuable information for me and also supplied this link – https://www.dropbox.com/s/aeehg9ssysh03xg/Suffolk%20Qualcast%20QX%20issu…
but unfortunately it doesn’t seem to be available any more.
Keith.
Last seen: 4 hours 38 min ago
Private message sent and the
Private message sent and the Dropbox file re-posted .
