35S Electronic ignition failure
Nigel N
Mon, 24/08/2020
Hi
Does anyone have a working one that they might like to part with, or know where I can get one?
Thanks.
Thanks, Chris, I've already
Thanks, Chris, I've already got them bookmarked but was joping for something a nit more economical. It's for my FIL and we're trying to keep the m/c running for a bit longer before it gets too much for him. We'll wait and see if one pops uo.
I can't help with a used one,
I can't help with a used one, and I believe the OE Wipac is obsolete unless there is some old stock lying around..
Given a working 35 or 43 can be had for as little as £20 it makes the decision to fix a bit difficult. Shame really as they are good little machines.
It looks like that is the earlier 2 pole? unless you have a corresponding flywheel you cant use the cheaper 3 pole coil
These examples are new remanufactured, Not advocating, just an example of the potential cost of new, buying used is a bit of a lottery.
https://www.jungle-busters.co.uk/Atco-/-Qualcast-Ignition-Unit-/-Stator
https://www.jungle-busters.co.uk/Atco-Qualcast-Ignition-Unit-Coil-2-Pole
