Atco clutch wear
Should
1manwent2 Mon, 20/05/2019
Sorry text disappeared the question was should I have the wear on the clutch ears welded or will I get away with it?also the two little springs are missing,are these available please?
wristpin Mon, 20/05/2019
Not too difficult to build up and grind back but left as is it will probably rattle a bit but should still work. Doubt if you will get the genuine springs but it may be worth asking Jon Cruse at the Hailsham Mower Centre.
The part number for the springs was H306
