Atco Commodore B20 Mitsubishi G221P Electric Start - The Restoration Continues
21 posts / 0 new
Mic2876uk
Last seen: 4 months 14 hours ago
Hi All First post.
I started looking for a newish second hand petrol mower and ended up with a cylinder mower as a project!
First task is to get it running, it has spark, seems to have compression (large resistance change on recoil starter with spark plug fitted). The electric start works. but so far no signs of life from the engine.
So far I have stripped the carb and liberally used carb cleaner. However I have found thanks to this forum that my particular carb is very hard to clean and ultrasonic cleaning is really the only way.
One thing i have noted is when pulling the recoil starter with air cleaner off it spits out fuel, however does not leak fuel when left with tank valve open.
Could this be down to a blockage or is it more likely the intake valve is not closing properly?
Spark plug looked dry suggesting fuel isn't getting into the cylinder.
I'm also fairly unfamiliar with carbs if someone had a diagram of my carb labelling all the adjustment screws explaining what they do and what I should try to get it running.
Forgot to add carb is stamped with Mikuni Corp
I will post photos later
Much appreciated
Michael
Last seen: 4 hours 59 min ago
Unfortunately that
Unfortunately that cabrurettor was total pain. Ultrasonic cleaning is probably your only hope of ridding it of stale fuel etc. Those little Mitsubishi engines ran at nearly constant revs it it was not unknown for them to carbon up the valve heads and stems so it may be worth giving it a decoke. I think that I've posted most of the specific Mitsu bulletins etc in the past but I'll sort out what I have .
Added
https://www.dropbox.com/s/lt7q0uhgvy5s2y2/Mitsubishi%20and%20Mikuni%20ca...
Mic2876uk
Hi wristpin thanks for your
Hi wristpin thanks for your reply.
I've attached a few photos and video of the carb and the valves (head removed) see link below
https://photos.app.goo.gl/MLhzGDfg5v7QShLc8
The screw / jet visible from the bottom clearly someone has tried to remove in the past and broken half the head off the screw, however the parts diagram I have doesn't show that as a removable part. Is it supposed to be removable or not? If so where could I get a replacement if not I guess I just have to hope ultrasonic cleaning can fix it.
If not where could I get another carb from as I have almost no information about the one I have are there suitable alternatives?
I have also attached a video which shows the intake valve closes almost at tdc is this normal?
Thanks again
Michael
I wouldn’t worry about the
I wouldn’t worry about the valve action as different manufacturers use different methods of achieving some compression release to aid starting.
I’ve got no personal recollection of dismantling one of those carbs but that slot head item that you highlight certainly looks as though it is a screw in emulsion tube or main jet, very similar to that in a Dellorto carb and I’ve seen plenty of those chewed up and generally mistreated.
As you have probably found out, nearly all references to Mikuni carbs seem to relate to either their motor cycle carbs or the later ones used on BS engines . It’s possibly a long shot but it may be worth contacting the Gateshead Mower Centre who bought all the Atco Spares when Bosch disposed of their lawnmower interests. That Mitsubishi engined machine had a fairly limited production run, consequently there’s not a lot of new old stock out there.
Perhaps you can post a scan of your parts diagram to add to the rather meagre information available on this carburettor.
Mic2876uk
Thanks again Wristpin,
For all the info and manuals I've gathered so far are in the attached shared folder below, I think all of this has come from trawling though this site;
https://drive.google.com/open?id=1NX5mSE3jIMbrWKDFFFGk6vhfxLqfHuW2
I will add to it if I find any more info, I would especially appreciate a workshop manual for this engine.
 I think that those bulletins
 I think that those bulletins etc were posted by me originally but the Atco Commodore one is not the correct one for the Mitsubishi engined machine, and as far as I can see there is no illustrated parts list for the Mikuni carburettor, only the Tillotson carb used on a different model.. I will post the Mitsubishi specific IPL / Operator’s manual when I’m back at the PC later but I’m fairly sure that there’s no breakdown for the carburettor.
EDIT
Here is the IPL and Ops manual for the Mitsubishi engined machine but as you will see there is no IPL for the Mikuni carburettor
https://www.dropbox.com/s/1ackso38a0vb1ml/Atco%20Commodore%20Mitsubishi0...
Ive got one other place to look but I don't think that Atco ever published a breakdown of the carb.
SECOND EDIT
Found this
https://www.dropbox.com/s/bkz3qf41xqxr5gh/AStco%20Mitsubishi%20ME1k%20G2...
As you said in your first post there is no sign of a removable emulsion tube or main jet. Seems a bit odd  - if it is a pressed in, non removable component, why the slot suggesting that it unscrews?
Mic2876uk
Thanks yet again Wristpin,
I had not managed to source the electric start manual thanks for that.
I had found the parts diagram for the engine which should be attached to my google drive link in my last post.
I've reassembled everything after giving the carb a good clean with carb cleaner and an airline (not ultrasonic yet) and still no joy.
I'm really starting to question the valve timing as shown in the video in my earlier post as when cranking with no air cleaner you can see an atomised mist of fuel being sent out of the carb the wrong way.
I've no idea why someone might have taken the engine apart and refitted it back together with the timing around 180deg out but i guess anything is possible.
I've also replaced the fuel line and added an inline fuel filter to prevent any further contamination and replaced the spark plug with the correct plug - after cranking spark plug looked dry suggesting its not getting any fuel
Video showing cranking with starter and fuel vapour coming out the carb
https://photos.app.goo.gl/2yj6pg7cEcEQsqyx9
I guess next step is have a look at the valve timing gear and see if there are any markings indicating correct timing
Unfortunately trying to view
Unfortunately trying to view your vid on the iPad caused all sorts of grief.
Take the head off and just go through the four stroke cycle - suck, squeeze , push , blow and see if the valve and piston positions correspond to what would be needed to achieve this.
180 degrees out would be immediately obvious from just viewing the valves. One tooth out, not so obvious . The crank shaft and cam gears will be marked, sometimes matching dots or even a chamfered tooth.
Does the engine actually show signs of having been pulled apart ?
Mic2876uk
I'll have to take head off
I'll have to take head off again to record the complete 4 stroke cycle, but the induction / suck part is shown in the video below
turning engine over by hand, no head intake stroke only
https://www.youtube.com/watch?v=IaWKWL2bMdk&feature=youtu.be
cranking engine with starter motor no head
https://www.youtube.com/watch?v=VS5mzz44C74&feature=youtu.be
trying to start - petrol vapour coming out intake
https://www.youtube.com/watch?v=2QTBcTf1YA4&feature=youtu.be
Hopefully youtube will be more ipad friendly :)
its hard to tell if its been apart recently but tbh i have no history of when it last ran
Last seen: 6 hours 43 min ago
Hard to tell from the short
Hard to tell from the short video, but it looks to me that it is the decompresser causing the slight lift and will not be the cause of your problems. The way it works is that there will be the main lobe on the cam that opens the valve normally, there will also be a slight 'bump' that slightly opens the valve to release compression at startup, once running it has little or no effect.
I would remove the valves and examine, them and if required, regrind them, I would also check the tappets.
Yes, your YouTube clips work
Yes, your YouTube clips work fine.
Carburettor venting, either external or internal, and the part played by atmospheric pressure.
If we are really pedantic over four stroke operation, strictly speaking,  to say that it sucks in mixture is incorrect. Lowering the piston creates a negative pressure area in the induction tract and the venturi effect of atmospheric pressure passing through the carb draws the fuel from the float bowl through the jets . To allow this to happen the float bowl is vented to atmosphere, either internally, probably via the air cleaner, or on some carbs via a baffled orifice directly through the top of the carb.
Where is all this leading to? Well, for the carb to function it must be vented so that atmospheric pressure may do its job so as well as ensuring that the jets etc are clear, make sure that the carb is venting. I have seen homemade gaskets between the carb and air filter effectively sealing off the vent passage.
Mic2876uk
Hi Hortimech thanks for your
Hi Hortimech thanks for your help!
I had to google decompresser and i found centrifugal force auto decompresser which my engine definitely doesn't have or are you suggesting the cam as a bump that always lets a bit of compression out? Also the systems tend to be on the exhaust cam as I guess you'd get a back fire through the carb if the intake cam wasn't sealing.
Hi Wristpin,
I'm still confused how a blocked orifice on the carb would allow air flow in the wrong direction if we are assuming the valve timing is correct.
Fuel is getting into the air stream but as far as i can tell from the brand new spark plug its not getting into the combustion chamber
Yes, if there isn't a
Yes, if there isn't a mechanical decompressor, then there may be an extra small 'bump' on one of the cam lobes that slightly opens a valve to release compression at startup. This can be on either of the valves.
Have you checked the flywheel key.? Unlike points ignition,  with electronic ignition the engine will spark regardless of the position of the flywheel trigger in relation to the crank position. so If the flywheel key is sheared or even partially sheared you spark may be occurring at the wrong time in relation to the other parameters required for ignition.
philreid@btinte...
Last seen: 3 months 3 weeks ago
Is there a known replacement
Is there a known replacement for this Mikuni carb?
I have tried all possible methods to clean it, but can only get the mower to run smoothly on almost full choke. I'm aware that these carbs are notorious for getting clogged.
Thanks...
Mic2876uk
Over a year on and it's still
post no longer applicable
Other than your typo, are you
Other than your typo, are you sure about the Atkinson cycle?
Mic2876uk
Not 100% but it would explain
As per the earlier posts on
As per the earlier posts on this thread it’s just the normal small engine decompression system for easier starting.
Get an aerosol can of flammable carb cleaner or general purpose spray and give a squirt straight into the carb inlet. If the engine gives a fire or two it confirms that there is a blockage in the carb.
Mic2876uk
Update... So I have now
Update... So I have now discovered why the valve timing seemed so wrong.
Someone decided that the key that drives the camshaft from the cam drive cog should be made from plastic. The key failed and the valve timing went out. Luckily I have access to a machine shop and a skilled machinist. so I have been able to get this made out of metal. Problem is the drive cog never had a keyway originally so we had to 'guess' where it needed it to give the correct valve timing. Also we accidentally made the brass spacer a tad too large this will be turned down if it turns out its causing issues.
I have reassembled the engine and put the valve drive cog back in so the intake valve opens just after TDC on the 'suck' stroke and the exhaust valve opens just after BDC on the 'blow' stroke.
I've also procured a replacement carb from ebay that dimensionally is identical to the original and it designs for an engine of similar power and size and duty cycle (small generator) https://www.ebay.co.uk/itm/Generator-Carburetor-For-Buffalo-Tools-Sportsman-GEN1100-GEN154-2-8HP-1500/303552658378?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649 I cannot guarantee this will work but I will update here if it does end up running the engine
At the moment the engine does not run as we now have the issue that potentially the ignition and valve timing is not correct.
But i've now had some smoke out the exhaust and pops of flames out the carb.
I plan to check the magneto to flywheel gap this weekend and play about moving the valve drive cog a few teeth either way.
New carb fitted
Mic2876uk
It runs!
It runs!
After turning down the brass spacer so that it didn't interfere with the exhaust valve opening the engine fired up... on its original carb
First fire up - https://www.youtube.com/watch?v=BVi-s1ENPu8
Idling - https://www.youtube.com/watch?v=Vm28zSoR2Aw
Cutting! - https://www.youtube.com/watch?v=yqczatDiMsE
So where do we go from here.
Firstly I need to dig out the manual and see if I can adjust the cutting cylinder.
And then... I was thinking of doing a bit of a restoration... not perfect but useable. I'm an engineer so I prefer functional over original... so the bike gear selector throttle will stay but the sticking cable won't and I plan to repaint it in Atco Green although that probably won't happen until next year.
