Atco commodore Valve timing
8 posts / 0 new
Henrik
Last seen: 3 weeks 6 days ago
Hi !
I can't find any timing marks on the camshaft or the crankshaft ? How can i time the valves correct ? This is my first Old mover I am restoration. Is there any repair manuals to buy ?
Henrik
Last seen: 1 hour 31 sec ago
Never come across one with no
Never come across one with no marks. Some good images of the crank and cam gears may help.
Henrik
I Will try to post some
I Will try to post some pictures.
henrik
Henrik
Here are some pictures. Hope
Here are some pictures. Hope somebody can tell me where the timing marks are ?
Lee Smallwood
Last seen: 52 min 49 sec ago
Would it have something to do
Would it have something to do with the hole in the large cog/gear, just guessing, maybe a mark on a plate underneath or casting has to be visible through hole. Im probably wrong.
NM
Last seen: 1 month 2 days ago
I can't say I've ever seen inside that engine but are the two dot marks arrowed the ones. Do they line up when you rotate the engine and can you then work backwards and set TDC and then timing on the piston and see if the marks line up.
Not easy !   Set the piston
Not easy !   Set the piston to  just past top dead centre  - not more than 6mm, and  then the cam gear on the rock - clearance on both valves.  Then look really carefully at the small segment on each where they meet. I would be looking for a tooth on the crank gear with a slightly larger chamfer on the side of the tip . If you can locate that look for some sign in the corresponding  area of the cam gear - such as a small centre pop mark at the base of the V between two teeth.
Henrik
Thank you, everyone. I will
Thank you, everyone. I will try to see, what I can find.
henrik
