Atco first start
7 posts / 0 new
JHock
Last seen: 5 months 1 week ago
Atco first start
Hello,
My 4 stroke ATCO with a suffolk motor started today. I flushed the oil twice and then ran it again but I get a loud metalic knock when under power. When I ground the plug and pull the starter there is no such noise. What do you think ? Rod Knock?
Now I know it will run I am toying with striping down the engine and rebuilding. Any tips?
Many thanks for any help,
James
Last seen: 5 hours 16 min ago
Could be a loose clutch .
JHock
Good point. Any ideas on how
Good point. Any ideas on how to diagnose/fix?
I can post a video on you tube if that helps?
Basically, just take all the
Basically, just take all the covers off and use eyes, ears and hands to check for loose components etc.
JHock
Good afternoon. Here is a
Good afternoon. Here is a link to a video. It had been running and is trying to run here but you can hear the clonking noise in the engine clearly......Video
I would say not internal
I would say not internal engine noise. Recoil starter ratchet may be.
JHock
Yes I think you are correct :
Yes I think you are correct :) Will give it a look tonight
