Atco Groundsman - Bolt Sizes
Good evening all,
Another rookie question if you don't mind..
Does anyone know what the bolt specifications are on a 1975 (ish) Atco groundsman 34? I am in the process of striping and rebuilding one and after ordering a small selection of metric bolts have come to the rapid realisation that they maybe the incorrect spec, are they imperial or other?
If anyone knows the correct type/specification could they suggest a recommended supplier of such bolts.
Some pics attached to try and help identify the year of mower (PS - it doesn't look like that at present )..
Thank you for your help in advance.
Scott
wristpin Tue, 21/04/2020
 Nothing metric on the Groundsman.
Early ones will be BSW ( British  Standard Whitworth) and BSF.  (British standard Fine ). Later  ones UNF and UNC. ( Unified fine and Unified Coarse)
Your  machine is most likely UNF / UNC
