atco mower - need help starting
6 posts / 0 new
Cbyatt
Last seen: 2 months 2 weeks ago
Need a bit of help here.
Given an old atco ..... heavy, powered roller, no name or model but think by looking at pictures it may be a B20 (20" blade?)
cleaned points and took off flywheel and cleaned throughout and then held the wire as manually turned the wheel and felt a jolt
Good news. But then the connector to the plug crumbled!! And .... looked at what I thought was the correct new pug and the arm was bent so obviously too long.
So, what plug would I need as a BP6HS seems too long?
Can I just buy a push on plug connector and this will work with the lead???
Cleaned all filters .. cleaned tank, carb so really looking for the final hurdle to actually getting this going.
What plug? What Lead?
Last seen: 19 min 51 sec ago
So what number is on the old
So what number is on the old plug?
An image of the engine or even of the old and new plugs side by side will save a lot of guess work.
Cbyatt
the old plug was very faint
the old plug was very faint but finally got bp6hs. Got a new one and it looked the same. Put it in an the piston strikes the plug tip but only just. All strange.
What size HT lead is it as well? just seems one thing after another trying to get this old girl going.
In-tank filter was solid, jets all blocked ... now just need to rectify this electrical problem
Cbyatt
Any idea what model it is as
Any idea what model it is as well? measured cutting barrel width as just under 20" but no distinguishing marks to be found.
NGK B6s or B2LM , both short
NGK B6s or B2LM , both short reach and ok for that engine. HT lead 5mm diameter. Looks like an Atco De Luxe 20.
Cbyatt
You are a font of knowledge.!
You are a font of knowledge.!! Great help. ordered a plug just now as well as a new connector bteween HT and sparkplug.
Fingers crossed !!
Let you know.
Thanks again
