Atco Standard Roller Dismantling ?
Hello Folks
I am at present restoring a lovely old Atco Standard and have discovered one of the outer rollers has a crack in it.
Does anyone know how to dismantle the roller assembly so I could get the cracked roller repaired.
Any information welcome.
Thanks in advance John (Yorkshire Dales)
wristpin Thu, 30/11/2017
A while back there was a thread on this forum on the same subject so it may be worth searching that out. If you are contemplating a welding repair, search out a qualified welder and not just "someone who can weld", as old cast material that has picked up various contaminants over the years needs to be treated with respect.
Clive1997 Fri, 01/12/2017
Hello
May be worth considering a replacement, there are many Standards out there being broken up, I have one at present, although wrong end of country!! Unless you fancy a trip South, (or Courier?) What cutting width is yours?
johntech Thu, 04/01/2018
Hello Clive
Yes it is a long way to come for a roller. But thank you for the offer
I dont suppose you have a decompressor valve I am strugling to find one!
Best Wishes John
