Bearings
3 posts / 0 new
Owd Potter
Last seen: 17 hours 47 min ago
Bearings
In relation to an old Qualcast Panther from 1957 can anyone give me the spec for the bearings that fit on the blade roller. I have tried a set of bicycle bearings standard cage design and also a better set from simply bearings but  both sets push the front end out of alignment. The original bearings were replaced a long time ago so I cannot see how they would have looked fitted on the cones.
Owd Potter
Last seen: 10 hours 38 min ago
There was a Push Panther, an
There was a Push Panther, an Electric Panther and a Power Panther. Which do you have.
Some  images of the old races and cones will help.
Owd Potter
It is the old manual push
It is the old manual push mower. I have now tried a combination of bearings and that seems to work but it is not perfect. By the by anyone know where I could get the half inch screws that hold the chain guard on.
thanks
