Clutch plates
Hi
Is it worth while taking the clutch plates apart and giving them a good sanding with 60 grit paper before re installing the engine?
wristpin Sun, 26/07/2020
I would try them "as is" first but if you do rough them up, consider that original plates will probably contain asbestos so do it wet.
Timmos Sun, 26/07/2020
Thanks Wristpin.
And good advice on Asbestos linings!!!
