Clutch plates on Atco HY
4 posts / 0 new
duncangasmith
Last seen: 3 weeks 6 days ago
The clutch plates on my HY are so firmly stuck together that I doubt I could tell which side the friction material should be fixed to. I suspect I may have to resort to heat or a saw. The parts list lists the items but does not say how they go together. Does it matter which plate I attach the new material to? The parts list mentions Friction material with brass liner. Anyone know the purpose of the bass liner? Perhaps to centralise on the shaft or act as a compression stop.
As for what material I have a supply of rubber bonded cork which is usually used for gasket applications or anti-vibration pads. Alternatively, I could use high quality compressed fibre gasket material or rubber sheeting. The cork material would be my first guess. Duncan
Clutch assembly
olcadmin
olcadmin's picture
Last seen: 1 day 12 hours ago
I believe the material floats
I believe the material floats and is not fixed to either plate - at least it's like that on all my Standards.
OLC Admin
duncangasmith
That probably explains the
That probably explains the need for the brass liner that is mentioned to protect the inner edge.
Many thanks
Ranso-mess
With respect to the friction
With respect to the friction material my first thought would be Ferodo or the like, as used in car clutches and brakes. Making it floating with a brass liner sounds not so easy, it is probably easier to bond the friction material to one of the disks. That seems to be not original however...
