Engine id
I have the engine below which I believe to be an Aspero/ Techusmeh the only numbers I can find are 1328028 on crankcase and 31.02.151 on flywheel maybe they are just part numbers it has a Ducati ignition and Dellorto FHC 20.3 carb
mikehpw1 Fri, 27/11/2020
Sorry I didn't say what I wanted. The model and a spares supplier please thanks
wristpin Fri, 27/11/2020
Engine. Probably an Aspera H30/35 (Tecumseh made under licence in Italy). Usually an ID plate riveted to the blower housing .
Parts. Wherever you can find them; eBay ,  Hailsham Mower Centre, or Meadowbrook Enterprises,  for starters, plus Euro Carb for Dellorto parts.
mikehpw1 Sat, 28/11/2020
Thanks Wristpin
sadly no  plate or number anywhere. Do you have any engine spec, ie bore. I need some bits and pieces but can't start search until I know which model it is. Cheers
mikehpw1 Sun, 29/11/2020
This club is amazing
wrist pin, bloody cock on !!  It's the very one. Ive now measured the bore and stroke so I know it's a 127cc engine, I've seen that number somewhere in my research but need to establish if its a 25,30 or 35 engine. Your manual covers all three. I'm almost there. An observation,  I ran my own machine manufacturing company for 45years, parts procurement wasn't always easy, but compared to lawnmower restoring it was a freekin breeze !!! Thanks again all
wristpin Sun, 29/11/2020
Not helped by the physical dimensions of those three models being  identical, so if the numbers refer to power output any differences are probably in carburettion / breathing, and top governed speed. Service parts  , coils, condensers, points and gaskets are almost certainly the same for all three and several other Aspera / Tecumseh engines of the same era.
If you need to go into the valves the clearance for both is between 8 and 12 thou”; beware of over gapping the exhaust which will cancel out the   compression release for easier starting and probably give a nasty snatch.Set both valve clearances with the piston 1/4” down the bore after top dead centre.
mikehpw1 Mon, 30/11/2020
Morning
You're right all service parts only have one pt no. However there are two sizes of block to cover three models. I need a piston ring set so I'll ring around  the suppliers. Parts list and drawing a great help though. Cheers
