Help-identification info
7 posts / 0 new
Jani
Jani's picture
Last seen: 2 months 2 days ago
Hello
I am new here,i am Jani from Kikinda,Serbia.
Need help on identification of lawnmouver -i am a total nob for this :)  sticker whit engine name fell off
the only numbers i find on her is this A  2/4  and 28330813
I only know or i think i know it is tecumseh  from around 1980-1985
What engine is this ?
and is it 4 cylinders, or 2 ?
Last seen: 4 hours 43 min ago
Welcome.
Welcome.
Probably a Tecumseh / Technamotor LAV35 or 40 or an LAVR35 or 40. It is a 4-stroke engine, that is plain petrol in the fuel tank and oil in the sump. You can see the oil dip stick just ahead of the fuel tank on the right hand side. The fuel tank cap is possibly not original, make sure that it has a vent hole to allow air in as the fuel flows out.
Jani
Jani's picture
ok,thank you M8 for the info.
it says 2kw or 2000  rmp is that 2.5 hp or ?
2 kw is aprox 2.7 mechanical
2 kw is aprox 2.7 mechanical HP but most older mower engines were governed to 3300 rpm and not 2000 so your engine is probably rated at around 3.5hp
Last seen: 1 hour 25 min ago
It is an Aspera LAV35, the R
It is an Aspera LAV35, the R in LAVR stood for: 'it has got a driveshaft stuck out of the sump to drive the propulsion on a self-propelled mower'
The Airshrouds etc changed when they came under the Technamotor banner
Jani
Jani's picture
Thanks for info!
Thanks for info!
Are you 100% sure that is it Aspera LAVR35 ?
gtc
Last seen: 2 hours 54 min ago
I believe that Hortimech is saying that it is NOT an LAVR35 because it lacks the driveshaft feature that the R signifies.
