Loose spark plug cable
bugbear
Mon, 22/05/2017
The spark plug cable keeps falling off the spark plug, which is frustrating. Is there a trick to tightening it up (it's just a push fit) or do I need a new connector (or even cable). The engine is a B&S on my rough mower (Hayter), if it makes a difference.
BugBear
That worked - thank you. I'm
That worked - thank you. I'm not confident how long term it will, the walls of the clip seemed very thin, and not very springy. But it'll do for now.
BugBear
Push back the rubber boot (
Push back the rubber boot ( if it has one) and pinch the loop with a pair of pliers.
