Qualcast Classic Petrol 35s
14 posts / 0 new
R1sahoot
Last seen: 1 week 6 days ago
Having enjoyed great success with the 1966 Webb Standard, it is time to reveal project #2.
Now why didn't I find these earlier this year / last year during lock-down
So we have....
The fuel system is bone dry, it took quite some time to get any fuel to appear in the fuel pipe and the carb bowl remains dry.
Weak spark - but at least there is a spark.
It's shows a lot more corrosion / deterioration than the Webb and right now the resting screws are seized so I cannot release the cassette.
R1sahoot
Ooooh it's looking like this
Ooooh it's looking like this ones going to be ugly....
The fuel inlet to carb is all scaled up.
the bowl is heavily corroded
throttle mechanism is stuck
whats that little micro switch on the throttle ?
Last seen: 2 hours 57 min ago
Seen as bad, but all doable
Seen as bad, but all doable including the corrosion etc around the cassette in your first image . As far as freeing steel to alloy fixings goes, Plus Gas is the preferred freeing liquid over any of the multi purpose maintenance sprays such as WD40. A home brew of brake/ATF with acetone is useful.
The " micro switch" is the "kill switch" that earths the ignition to stop the engine - always assuming that it runs !
R1sahoot
So throttle cable is rusted
So throttle cable is rusted to its sleeve have spent afternoon working it back and forward and soaking it in pen oil.
float is seized / rusted in place
soaking screws hourly in pen oil hoping I can liberate the cassette, I believe it is possible to remove the roller and get at the back of these.
cannot release screws holding drive shaft in place
so does the micro switch connect to anything on the throttle mechanism ( there is a curled wire hook sticking out ) or does it simply get pushed back and forward ( I really need to get to multimeter out and test its function)
unlike the Webb this is  going to need more than 8hrs of effort ho ho ho
R1sahoot
In last post I referred to
In last post I referred to "drive shaft" I actually meant "drive shaft cover".
also struggling with pull start cover apart from the two on top is there anything else I need to remove undo in order to release this ?
The curly bit of wire is
The curly bit of wire is "live" to the electronic ignition module (no points or condenser) and the mechanical throttle/governor linkage touches it when the throttle is moved to the stop position.
R1sahoot
After some attention with
After some attention with penetrating oil the cassette is out !
R1sahoot
Ok so activities have halted
Ok so activities have halted momentarily as the controller of free thought decreed that we must visit other nations, lay on beaches and drink beer with unusual names.
Back in 10 days ….
R1sahoot
Just returned from having to
Just returned from having to endure 10 days of the above.
Back now and after a couple of hours cleaning and smartening up the engine.
Have fitted a new air filter and plug and it runs !
R1sahoot
Rusty (seized) throttle cable
Rusty (seized) throttle cable that I left soaking in PenOil 10 days ago has freed off lovely.
The engine stop  "micro switch" also working reliably.
Now about that "cassette"
Floydism
Last seen: 1 hour 21 min ago
That looks like it's going to
That looks like it's going to be a pig as far as welding goes, it's probably more rust than steel, I'd bet there'd be an awful lot of pin-holes if you attacked it with a wire-brush, you'd forever be chasing holes with the torch.
Making a replacement is probably the only sensible way to go, how are your tin-bashing skills? you could probably do without the swaged stiffeners as they're very difficult to do nicely even if you've got the appropriate machinery. (but do-able for the intrepid DIYer)  but the rest would be fairly simple to replicate. If you've not got a sheet-brake handy you can make a bender from a couple of bits of angle and a vice/clamps with a piece of wood and a hammer to gently tease a nice sharp bend into it. and gradually curving it over a scaff-pole would get you the bulk of the shape.
R1sahoot
An interesting few hours
An interesting few hours today.
Engine is starting 1st pull, needs an oil change but there's no sign of any water contamination, not sure why there are two ports, one with a dipstick ( below the carb) and one (narrower) on the other side of the engine. Is it a Kawasaki engine ?
Regarding corrosion... I am now at a junction, as correctly observed it is starting to look like a pig. I removed the roller this afternoon to unearth more ugly corrosion, I have spent next to nothing (and very little time ) getting the engine  running reliably and looking mint but the main chassis and "cassette" are another story.
Will post some photos tomorrow morning together with my thoughts re; next steps.
If you don’t fancy the tin
If you don’t fancy the tin bashing the deflector is still available, F016103707. £20+vat
Floydism
Wow! still available! That's
Wow! still available! That's no fun at all!
