Ransomes Ajax Mk5 refurb
37 posts / 0 new
Warpa
Last seen: 2 days 6 hours ago
I have some questions as I've never restored anything before.
Do you wire brush the nuts and bolts up so they look newish again?
Is the silver cover supposed to be painted or an aluminium finish?
Are my selection of flappy discs good to clean up all the heavier corroded parts?
Can I refurbish the cylinder myself or is that best to be sent off and dipped?
I also need the following parts if anyone can help.
Part 50 Carriage left hand
Part 35 Setscrew scraper
Lee Smallwood
Last seen: 7 hours 6 min ago
The side plates aren't
The side plates aren't painted,, I've seen them highly polished or left with a patina,  I've sent some cylinders off to get media blasted, I've also used a wire wheel in a cordless drill to clean them up followed by sanding by hand, depends on the restoration and if it warrants any expenditure, for the nuts and bolts, a wire brush is fine, wire wheel on a bench grinder gives a little more control though, a flappy disc will take metal with it so be gentle if you use one, but it will sort the pitting out a little faster than sanding,( especially by hand)
Lots of mk 5s around for sale on eBay and the like, shouldn't be hard to find a doner.
What I have found on the the handful of mowers I've tidied up, you can never have enough notes, photos and little labels,  it can be weeks before the mower is being put back together, especially if sourcing spare parts, or waiting for refurbished parts to be returned, it can get confusing if you have everything in one oily box...
Warpa
I've found the roller part I
I've found the roller part I need, just need the set screw, but may just buy 2 new ones. I've not stripped it fully but will label everything in sandwich bags ( I should know better as all i watch on TV are car restoration programs)
I have metal polishing equipment albeit not professional but I can still make a mirror finish from a rusty piece of metal. I have a brand new grass collector and it doesn't look like there is any lacquer, did they use it in the old days or is the Ransomes green paint the final finish?
One last question, when I grind down all the pitted corroded parts, will metal primer and undercoat be enough before the green goes on?
cwj123
Last seen: 5 hours 33 min ago
All mine have painted sides.
Warpa
Was that the factory finish
Was that the factory finish or a part of restoration? Mine looks untouched and still had green paint on the inside of the rollers, if the sides are aluminium I dont see why Ransomes would paint it.
Last seen: 1 hour 48 min ago
Bear in mind that although a
Bear in mind that although a better quality machine of their day they were just a working tool and any form of bling would have been out of the question. As far as nuts and bolts and other hardware goes it would probably have been "black iron" in natural finish - no stainless, no plating and no polishing. possibly a bit of silver paint.
Patina is only original once!
cwj123
Original from factory there
Original from factory there is one for sale on ebay at the moment clearly showing paint.
If it's the one with the "white marble" front roller , I very much doubt that the green painted side plates are original.
Edit. Second thoughts! The drive side, cover looks similar to the Anglia so were the Mk2s painted iron/steel  and not alloy? One for Clive, me thinks.
Antbr123
Last seen: 2 days 8 hours ago
Two options open to you.
1.  Buy new fasteners.  Readily available from sources on this website (Namrick).  I use Mike Peters at www. Polished-Stainless.com also known as Surplus Supplies.  Tel 01636 636735 He is always helpful, and very quick delivery.  You will need to know the thread type. BSF? It is personal choice if you go this route as most modern manufactured fasteners have rounded edges and not flat surfaces as old imperial fasteners.
2.  Soak the original fasteners in white wine vinegar or cider vinegar. for 2 days  Its cheap from supermarkets. Afterwards use a small wire brush.  It is worthwhile investing in a set of die nuts which can be used to clean threads of shafts, bolts, set screws etc, particularly if you get the bug and intend to restore multiple mowers. I use Tracey Tools Tel 01803 328603
Regarding the vinegar - I buy it in bulk from Amazon, but it is superb at getting rid of rust.  I use it in a plastic garden planter and even soak larger items, such cylinder blades after paint stripping. It is apparently sold to Chinese takeaway restaurants..It is 5% acidic so is safe to get on your hands, and even after 2 weeks of soaking parts have not been eaten away...but the rust removal is effortless. I do recommend washing your hands afterwards...just to be on the safe side.
regards,
Tony
Antbr123 (Tony)
cwj123
The sides see ebay
The sides see ebay
283634014056
Last seen: 2 days 2 hours ago
A bit expensive I often
A bit expensive I often struggle to get £10 for a whole mower or sometimes can't give them away, there are many Ajax's out there.
cwj123
Not to buy but to show paint
Not to buy but to show paint.Clive could you see if sides painted on others you have?Thanks
Warpa
Rather than going the full
Rather than going the full restoration on this Ajax would I be better off using it as a learning curve for a Certes? The mowers i do will be used by myself.
Warpa
Part 35 setscrew scraper I
Part 35 setscrew scraper I cant find to replace as I have no idea what its technical name is.
Last seen: 2 hours 31 min ago
Yes you do, it is a setscrew
Yes you do, it is a setscrew that holds the scraper on ;-)
A bolt is, well, a bolt that isn't threaded all the way down, a setscrew is a bolt that is threaded all the way down.
Are you sure that is the right setscrew ? (the one in the pictures), I would have expected one with a hexagon head and that appears to be one with an allen key head. The other thing to note, it will not be a metric fixing, it will probably be a BSF fixing, but may be a UNF one.
AUTO CERTES 1
Last seen: 1 month 1 week ago
This is a picture of my mk5
This is a picture of my mk5 Ajax. You should be able to see the original hammerite silver paint on the aluminium side plates.
cwj123
Yes thats the paint that
Yes thats the paint that mines are,so must be original.
I think that you may be going down a dangerous road with the use of "must".  I have two unrestored Ajax , a Mk3 and a Mk5  and neither have  any sign of hammer finish paint on the side plates . Note "hammer finish" not Hammerite which was the trade mark of the hammer finish paint sold by Finnigans  of Prudoe  and still is that of the  AkzoNobel company who now own the brand.
Set screws. I would suggest that those socket head set screws are not original as I've never seen socket head hardware on Ajax machines. As observed by Hortimech , hex head would be more likely.
As has already been discussed, it was common practice for cutting cylinders to be stripped and repainted . We would often tidy up a used Ajax for sale by rubbing down the side plates and giving them a blow over with whatever silver paint was to hand or even just a clear lacquer.  The deflector plates would also be stripped, de-rusted and repainted with whatever green or black paint was in the gun. While on the subject of deflector plates, did all genuine Ransomes ones have pressed in vertical stiffening swages ? One of my machines has, the other has not, but has a neat horizontal turned over stiffener along the top edge  - original or a dealer made replacement?
cwj123
You are quite right,should
You are quite right,should have said looks as though.
Warpa
I did wonder about the
I did wonder about the setscrew being an alen key head on it. I also see in the last photo the roller is not painted, mine has a bit of green paint left on the inside. I prefer the un painted finish myself.
Am I safe to say that I can pretty much go for whatever colour scheme I want whether its sold on as a refurb or kept for myself? My choice would be unpainted roller and polished and lacquered sides. I also prefer the handle joiner in silver instead of red.
When I refurb a Certes it will be a personal bling model with new stainless fixings.
Warpa
How do I remove this last cog
How do I remove this last cog? It doesn't feel as though it wants to pop off so I'm assuming it needs to be unscrewed somehow?
Warpa
The quality was awful, here's
The quality was awful, here's another.
Warpa
I found an old post on here
I found an old post on here about how to remove it. The final piece to remove is the spindle from the plate, how do I manage that?
Antbr123
You should be able to knock
You should be able to knock or gently tap the pin through the shaft.  I use a flat centre punch.  Do not welly it...you are likely to burr over the end of the pin making life difficult for yourself....Once you have got movement keep tapping it all the way through the shaft until you have enough purchase on the other end to pull it out.
Antbr123 (Tony)
Warpa
Erm, what could go wrong is
Erm, what could go wrong is that I sheared it. I cant for the life of me find a spare any where.
What diameter ?
What diameter ?
Warpa
3/16 by 1 and an 1/8 to one
3/16 by 1 and an 1/8 to one and a quarter long, and now its clean I see why they call it a grooved pin. Is it necessary to have  grooves if its held  in fast in the main drive cog?
Usually referred to as a
Usually referred to as a Mills pin. Sometimes they are very slightly bulged but other times look as though someone has applied a sharp cold chisel, longitudinally at the four points of the compass. Those grooves or swages supply enough friction to keep the pin in place.
You may even find that a six inch nail is the right diameter.
Warpa
Thanks for that wristpin, so
Thanks for that wristpin, so it's not crucial its grooved to really secure it in place?
As the recess in the gear
As the recess in the gear wheel has closed ends the pin can’t fall out. When you find or make a pin make sure that it’s a snug fit .
Warpa
I have had a search on here
I have had a search on here and found a post kind of describing the info I'm after. I'm trying to separate the landroll and can get a 1/4 gap between the two and that's it. I dont want to force it as it feels as though there is something holding it there.
Firstly should the gears just pull out, and secondly have I missed retaining screws somewhere? Looking at the parts pdf I see a a pawl and a spring for pawl, I cant see those parts in all the old grease, would they be stopping the separation?
Warpa
I managed to separate the
I managed to separate the rear roller eventually with a lot of heat and hammering. I had the same issue as the person I found in a search here, the srew to secure the pawl was not on the flat part of the spindle and had created a groove stopping removal. I'm glad I persevered as it is so smooth now and I'm now able to start to re assemble.
Warpa
Well I am very happy with the
Well I am very happy with the result so far lol
RedLeader
Last seen: 6 days 12 hours ago
Well done Warpa, that looks
Well done Warpa, that looks really good so far, and well done for persevering with your first restoration. I hope my Suffolk looks as good when I eventually put it back together, having never done a restoration before either!
Warpa
Thank you, it is very
Thank you, it is very satisfying and will be looking for another to do. I already miss the old grease and parts that wont budge!
Jonson
Jonson's picture
Last seen: 5 hours 22 min ago
Hi Warpa. You are doing a
Hi Warpa. You are doing a fine job there with that Ajax! May I just ask what green paint you are using, and do you find it a good match to the original Ransomes green?
Regards,
Jon
Warpa
Hi Jon, I've used Spaldings
Hi Jon, I've used Spaldings ransomes green. I'm not sure on its accuracy as a perfect match, but is I think a lovely green. I also used the same company for the cylinder red.
