Ransomes Certes Mk12 (Help Needed Please)
10 posts / 0 new
Mower1
Last seen: 1 month 1 week ago
Hello,
I’m in the process of dismantling a Ransomes Certes Mk12 and need advice on how to separate the two sides please. Do I need to remove the circlip first (see red arrow) and will I need a special tool to engage in those slots in order remove the assembly. There is an arrow on the side cover showing the direction. (See black arrow)
Thank you.
Last seen: 7 hours 29 min ago
Long time since I stripped a
Long time since I stripped a Certes, but if I remember correctly, the circlip retains the bearing in the housing, which unscrews. You will need a C spanner to turn it.
Last seen: 1 hour 43 min ago
Definitely a job for a C
Definitely a job for a C spanner or, depending on the availability of materials and skills, a homemade peg spanner. To preserve the integrity and originality of the machine, resist the temptation to knock it round with a punch.
Mower1
Thank you for the replies. I
Thank you for the replies. I don’t have a “C” spanner and having just looked at the parts list under the “Tool List” section there is a tool called “spanner – Landroll Housing” :-)  I will try and get a C spanner tomorrow.
https://www.oldlawnmowerclub.co.uk/sites/default/files/opmanual/Ransomes%20Certes%20Mk%2012%20%28Post%201972%29%20Parts%20List.pdf
Plenty of C spanner’s on eBay
Plenty of C spanner’s on eBay, some “adjustable” for the diameter of the component. May  be worth trying the cycle dept of Halfords as push bikes use bearing retaining rings tightened with such tools . Arm your self with the diameter of the retainer before you go shopping .
Mower1
Thanks Wristpin
Thanks Wristpin
AUTO CERTES 1
Online
Last seen: 11 min 50 sec ago
Hi Mower 1
Hi Mower 1
I've just stripped down a mk12 this week too and always use a C spanner. As you turn the bearing housing it draws the bearings off of the hex shaft. Then if you want to get the bearings out of the housing you will probably need bearing puller of some sort. Have you got a decent grass box for it and has it got all the original paint? Should be hammerite silver on the aluminium and brass height adjusting knob and fairly light green everywhere else save the spiral cylinder.
Mower1
Hello Auto Certes 1 – Thanks
Hello Auto Certes 1 – Thanks for the reply. Did you need to remove the circlip before unscrewing the Landroll Housing.No grass box or any paint on this mower.
I take it back when I said I didn’t have a “C” Spanner I have just found a couple in my shed. I picked up a small box of old spanners some time ago and forgot I had them. I really need to do a complete audit of my shed as I appear to have lost track of what tools I do have :-)
The “C” spanner I have doesn’t quite fit, so not sure if it’s worth spending an hour or so re-shaping the spanner for a custom fit, or buy one? As the Landroll Housing presumably hasn’t been removed since it installation its removal may not be easy.
AUTO CERTES 1
Online
Yes if you have the circlip
Yes if you have the circlip pliers it takes seconds. A couple of pounds from eBay. Would it be possible for you to upload some pictures of the mk12 with close ups of the land rolls and spiral cylinder please?
sawfingers
From the looks of the burrs
From the looks of the burrs on the retaining ring somebody else didn't have a C spanner has gone at it with a hammer and punch. If all else fails give it a good soaking overnight in some diesel or similar and try some sharp but gentle taps with a metal chisel or old screwdriver in the slot
