Ransomes green, pre 1985
12 posts / 0 new
Andyp
Hi, I have read many posts on here about Ransomes green paint but the one that is readily available from many sources appears to be a darker shade than the paint used pre 1985. Does anyone have a source or a colour code or RAL number for the earlier Ransomes green paint?
many thanks
Andy
Triumph66
Last seen: 3 weeks 2 days ago
Andy,
Andy,
A very good question and I hope someone on here can give you the definitive answer. I will be looking for an appropriate colour for my JP Maxees at some point too.
Chris G
Chris G's picture
Last seen: 1 day 6 hours ago
If you have a good bit of
If you have a good bit of original paint this can be scanned and reproduced at B&Q etc but they have minimum order of 500ml I think.
I have not searched the site but the answer could well be on here already in the restoration links.
Ransomes green is indicated as 992 on this colour chart link, but just something I saw on the net so no experience of that..
https://www.teamacagricultural.co.uk/uploads/files/TM_Colour_card_Indust...
Antbr123
Last seen: 3 hours 36 min ago
Hi Triumph66 - thought I
Hi Triumph66 - thought I would drop you a quick note.  I am a collector of JPs and restore them as well.  Just finishing a JP Maxees - 14 Mk2 hand push to factory condition.  I have been working with Henry Ellis for a few weeks who is the recognised expert on JP's.  The paint he recommends is from Halfords Vauxhall Leaf Green spray paint.  You can find it on the Halfords website by searching.  I founds I needed 3-4 cans to do a decent job and use a grey undercoat as it seems to bring out the depth of colour better.
Something to be aware of.  JP seem to have changed the colour tone of the green they used.  But it does not appear consistent.  Some of the green are more of an apple green colour- but if an overall finish is required the Halfords Vauxhall Leaf Green spray paint is as good as any I have found. Good luck with the restoration.
Antbr123 (Tony)
NM
Last seen: 1 month 11 hours ago
If you’re spraying from a
If you’re spraying from a spray gun could you get some blue and yellow and adjust tints or black and white to alter shade.
A bit expensive and trial and error but if you keep a record of weights added future mixes should be reasonably consistant.
Chris G
Chris G's picture
Does anyone know if this
Does anyone know if this ransomes RAL 992 is correct?
Andyp
Chris, I am struggling to
Chris, I am struggling to find an online example of Ral 992. We are looking at Ral 6032 and 6024 but have not made a decision yet. I will let you know.
Lesley
Last seen: 2 months 3 weeks ago
Dingbros (motor factors in
Dingbros (motor factors in Scotland) their Edinburgh Seafield branch (and no doubt others) are excellent at matching paint and have in the past made up both spray can and tin for my husband, excellent match.  You will want to say you're trade or get your friendly local garage to help.
Lesley
Andyp
My brother in law has
My brother in law has finished his restoration of an Ajax Mk5 and the paint he chose after testing 3 others was marked as Pantone Green ref 348c. I have not seen the finished article in person only via WhatsApp video call but the colour looks spot on. I do not know what the RAL equivalent is
Hope this is of use.
cheers
Andy
One of the problems is
One of the problems is knowing exactly what colours are being compared. Until the 1970s it was not unusual for dealers carrying out a full winter service, to respray complete machines and the paint used may well not have been the exact factory shade. I have a 1960s Ransomes winter service tariff for all their machines from push mowers to mounted gangs with, where appropriate, three levels of work , cutter unit service, complete machine service and full overhaul . In each case a degree of repainting is specified.
In theory it should just be a matter of asking Ransomes themselves but from previous posts and answers on this, and other, forums it seems that Ransomes are not very forthcoming on the subject. I’m not sure what to read into the lack of information from Ransomes ; maybe the records are incomplete or maybe the shades varied batch to batch and no records were kept from the outset. May be worth asking HDTrust, or failing that getting OLC to make an official approach to Ransomes so as to put the matter to bed for once and or all.
gtc
Last seen: 8 hours 9 min ago
A very good idea, methinks.
The issue is, whether one is matching to original unfaded paint or someone else's respray. Unfaded areas under handlebar grips or inside chain or gear case covers are probably as good as it gets for colour matching.
Another post mentions a Pantone number. The Pantone system for colour matching is mainly used by the printing and graphics trades and can be cross matched to the RAL and PPG, Lechier,RM and MaxMeyer etc.
