Ransomes Marquis failure to start
Hello everyone. I've got a new to me Ransomes Marquis Mark 4A with Villiers engine and Amal carb.
I started it this morning as per the manual and it fired up and ran - however slowly started to sputter and then just stopped running altogether.
I have tried restarting with the choke on, choke off and a mixture of throttle etc but just won't start.
Am I doing something wrong?
Is it even getting fuel
Is it even getting fuel delivery from the tank to carb? Plug wet or dry as a bone....or just pitch black
Sorry for the slow reply!
I ended up taking the carb off and cleaning it, out it back together and started straight away. I should have done that before posting here really...
Welcome to the world of
Welcome to the world of classic mowers.
Take the spark plug out and check for a spark at the electrodes. No spark there , remove the connector and check for a spark off the end of the HT lead. Spark there, try a new plug. No spark there will mean that at the least the contact breaker points need cleaning and adjusting . Possibly a failed condenser or worst case the coil.
If all is well in the sparks department, strip and clean the carburettor.
