Suffolk Punch 17S cylinder bearing oil seals
I am looking for the oil seals that protect the cylinder bearings on my Suffolk Punch 17S mower.
The bearings are the older type with the sliding bearing cone on one end of the cylinder shaft.
Outside diameter of oil seal is 1" 7/16 and bore is around 15/16". Thickness is 1/4".
Mike.
bearingoil seal
wristpin Sat, 20/06/2020
They were pt No F016T40266 which are shown as obsolete.
Suggest that you try Jon Cruse at the Hailsham Mower Centre.
