Techusmeh / Garden Master carb
5 posts / 0 new
mikehpw1
Last seen: 1 day 18 hours ago
Evening
Im about to rebuild a Techusmeh HTB 25/30/35 on a Garden Master 85 and I could do with a photo of the carb showing linkages and governor spring. I have an exploded drawing kindly posted by Wristpin but it's not detailed enough to show exact set up. Thanks
Last seen: 4 hours 41 min ago
It's TECUMSEH !
mikehpw1
It's a great scrabble find,
It's a great scrabble find, how many is it worth??  Up trumps again Wristpin (-:
Last seen: 6 hours 30 min ago
No, its Aspera !
No, its Aspera !
mikehpw1
Morning
Morning
both names would be worth a few points (-:
well on checking the docs that you sent Wristpin, as I'm coming to expect mines slightly different in that the governor spring isn't attached to  the governor arm but to a bracket on the throttle. The spring is actually missing so when I locate one I might be able to figure it out. But if there are any pics out there it would be easier thanks
