Villier midget Mk1 crank removal.
3 posts / 0 new
Andy18g
Last seen: 2 months 10 hours ago
Have a Mk1 midget, 1952?
Trying to remove clutch dog so can remove crank from case.
Is this a standard RH thread and just requires more force to remove it?
Anyone with info on successfully removing it?
Last seen: 4 hours 28 min ago
I think that there was a
I think that there was a thread on this subject a while back but it has a RH thread so that the direction of engine rotation does it up. Warm it up and with a soft steel drift against one of the lugs, give it a sharp smack.* Not wise to attempt to unscrew it while holding the other end as there is a risk of twisting the three piece crank.
* EDIT the action of being screwed on forces it onto a taper - hence the need for a bit of a shock to get it moving.
Andy18g
Wristpin. Thank you for info.
Wristpin.
Thank you for info.
