Atco B20, runs and dies, its the dying bit Im having a problem with :)
Hi Team
My Atco is having problems, (mainly with me I think) it runs for about 3 /5 mins, then stops, and smoke comes out of the exhaust box.
So I have bought new spark plug and oil.....
The petrol is new. it has not been sitting in a can for 2 years..
and I also seam to have a leak..
I should go out and get a hover, but where would the fun in that be....
Thanks for reading ..
wristpin Mon, 25/08/2014
First slacken the fuel fill cap and see how you get on. Could be a blocked tank cap breather causing the tank to vacuum.
Second, what colour is the smoke, white or black?
wristpin Tue, 26/08/2014
OK, suggest that you go ahead with the loosened tank cap. If it has been running with the plug  in your first image there are no signs of oiling , in fact it looks very clean and may suggest a weak mixture which goes with the possibility of fuel starvation caused by restricted flow from the tank.
