Front Rollers wanted, Webb 14" petrol mower
Could any member point me to a source to obtain replacement new rollers with the following  dimensions?
External diameter    65mm
Internal diameter     17mm
Required Length      3 at 100mm,  and 2 at 50mm
Many thanks
hillsider Wed, 28/07/2010
Hello re the new rollers for your Webb mower you may try searching your area for someone who has a woodturning lathe who may be prepared to make them for you as a project in return for suitable remuneration. Hopefully other members reading this may know of an alternative source and post directions also.
Ray.
Brian Latham Fri, 30/07/2010
Thanks Ray
I have now been recommended to Southport Lawnmower Museum, 01704 501336. They say they will obtain the rollers for me.
Brian
hillsider Fri, 30/07/2010
Brian,
That's ok, I imagine that coming from there the rollers should be spot on if the restorations on their website are anything to go by.
Ray
