I need to Date the following two Ransomes Mowers Please
I thinks will be able to restore 1 of them pending spares availability
It will be intersting to determine the year of Manufacture
I'm not familiar with the Majestic but at 24" its unlikely to be a "bowling green" mower and the same applies to the Matador which is a fairly heavy duty general purpose machine. With those serial numbers, Ransomes themselves will be able to date them. Parts for the Matador should not be too much of a problem. Not sure about the Majestic but a lot of Ransomes models, of a given period, used common components.
I have heard of, but never seen a majestic, I may be wrong, but wasn't it an electric matador ?
I would love to see a picture of it.
As Wristpin has said, neither will be any good for a bowling green, not enough blades in the cylinder and a lipped bottom blade, they just will not cut close enough.
Hortimech's comment about the Mjestic being electric nudged my memory - I have an owner's manual. Yes it appears to have been a Matador chassis with an off the shelf Brook 1HP electric motor bolted on. Almost certainly with a three core earthed cable; none of the niceties of double insulation and plugged into a household system with wired fuses and no earth leakage trip or RCD.
https://www.dropbox.com/s/zq0vn3l3y8chhk9/Ransomes%20Matador%20and%20Maj...
I got one thing wrong, you could use it on a bowling green, it has an 11 blade cylinder and presumably a thin bottom blade. I wouldn't have thought it would have been used by golf clubs, just think of the length of the extension lead you would need LOL
I wonder if the other machine has the same cylinder in it ?
I really think we need photos .
Certainly it appears that a multi-bladed cylinder was an option but 10 not 11 blades and , yes , there was a thin bottom blade. No mention of the length of the cable though!
Look to the left of the image and it appears that a three blade cylinder was an option - amazing! Shades of Reel Cutter and Multimower.
https://www.dropbox.com/s/s7io3kv79a031a2/Ransomes%20Matador%20and%20Maj...
Thanks for the information to date
Both come from Lower South Coast Bowling Clubs in KZN South Africa and was used as Bowling Green Mowers
The Matador has been stripped completely and came with no cutting reel but had a 9 hole Bottom blase. The Cutting Cylinder was Rust destroyed.
The Majestic was converted to a vertii cut Groomer blade see attached Photo.
I intend to restore One as a Mower from the spares I Have ( we have great Rust Problems at the Coast in KZN)
I need to lay my hands on a parts manual can any one please advise how and where I need to go
Had to Google KZN, but now it starts to make sense!
This is the best that I can find but it doesn't fit the scanner and the part numbers are well out of date. However , if there's a particular page of interest let me know by PM or email and I will do a full size scan and possibly come up with more current part numbers.
https://www.dropbox.com/s/ngaz3fqo8axbh7r/Ransomes%20Majestic%20Matador%...
If this is any use to you, please print them out as I wont leave the link live for ever as it eats into my free Dropbox space.
If you email Ransomes in the UK there is a possibility that they may have digitised the relevant parts manuals and can send them to you at the touch of a button or two.
Thanks for the information I have downloaded it to my drop box .
Parts seem to be available here in South Africa and your manual will come in Handy
Who can I email at Ransomes with the serial Numbers to try and date the Machines?? please
I have successfully stripped My Morisom and will start the restoration soon
I am in contact with Morrison (Masspart) Nw Zealand with out success .Has any one got a contact with the original Morrison perhaps for me?
The Morrison brand was owned by Masport. I say was as it’s just been announced that both have been bought by the German garden machinery manufacturer, Al-Ko Gardentech.
Possibly of more help to you , OLC club member FInnkai has been working on a Morrison and has been in contact with a helpful contact so it could be worth a private message to him.
I am battling to make contact with
1) Ransomes Can any one please let me have contact e mail For dating purposes
2) Any lead into Australia or New Zealand regarding my Morrison
Any contact would be appreciated
Ransomes website in the UK is
http://www.ransomesjacobsen.com/europe
As per my last post , forum contributor FInnkai has already done most of the leg work in unearthing Morrison contacts.
Herewith a Photo of the Majestic
It is currently got a spring steel verticut blade segments in it as a cutting reel, It was last used as a Groomer/Verticutiing
Unfortunately Not one of the machine's have either 11 or 7 blade cutting reel , this will be one of the components i will have to procure.
How do I get in contact with Ransomes to try and date the Machines?
As Wristpin said, Ransome has a webpage, but to be a bit more explicit, go here:
http://www.ransomesjacobsen.com/europe-contact-us/
Thanks Wristpin
Done and have submitted the questions via the website.
Any one egot a detail Plan or Sketch for the Matador or Majestic Grass Box as I will have to Make IT up
Looking at that site I see that South Africa is not listed, which possibly suggests that it is served from America, but hopefully Ipswich will point you in the right direction.
Cut to the chase Bill, and ask the right people!
Your 24" Matador was built in June 1966
Your Majestic 14B was built November 1964 for the 1965 Season
A note to other enthusiasts who have tried to help, other countries have different climates, which mean different growth pattern to varieties of turf grasses used.
Ransomes in many cases when exporting,altered their machines accordingly,
A perfect example is Belgium,only bodies of mowers were sent, the agents put their own engine units on
Try the professionals
The Hall & Duck Trust
Thanks Hdtrust
That makes a lot of sense and being such a rust infested area KZN South Coast .
It is logic that Bowling Clubs being in close proximity will procure similar machines.
The Majestic come from the Umtentweni Bowling Club which was established in 1933.
The Matador from Southport Bowling Club established 1934
So the years of 1964 and 1966 is fitting in well.
The above clubs , TheBell and Port Shepstone Country Club Bowling green machine are now mainly electric 30 inch Scott Bonners, Protea's or RSA Turf masters.
Restoring has begun and will post progress pictures in the new year
I used matadors in the 70s/80s with a 258cc MAG engine. Thought they were a heavy machine for a 2 foot cut,when a 20" marquis with the delightful BSA sloper engine was far lighter to use and transport to site.Also the chain adjustment was easily spoilt by clipping a cerb or pebble.That said it cut well and has 2 box arms to aid emptying. Good luck with your restorations.
How time has flown since my last contact, was kept busy maintaining existing Bowling green mowers so the restoration of the Ransomes was delayed, some progress has been made on the Morrison Pictures to follow
With the event of covid and lockdown I hope I will be able to start working on the Ransomes sooner than later.
Any body have the Ransomes Green Colour code
Only spotted “electric 30 inch” when reading through the old posts. That’s one heck of an electric mower - battery or on the end of a wire?
I looked after a few Matadors in my time, but no greens ones, last ones I servided had Swiss engines in, but odd American carbs. the Mastiff comes to mind also.
