Atco B14 with Suffolk 75cc engine
I have recently acquired a nice example of this Atco and would like to find a copy of the service manual for the mower and its engine. Is there one on the website somewhere as I can't find it? If not can someone point me in the direction of one please.
Osborne Sun, 13/01/2019
Thank you for that, perfect! Can you clear up a slight confusion as I was advised that the machine is a B14 with the Suffolk 75cc engine but it seems that it is called B23, and I have found a small dirty plate on the side stating such??
Best regards
wristpin Sun, 13/01/2019
B23, new one to me . I’ll have a look at various manuals etc and see if there is a clue. Any chance of a pic of the plate?
EDIT
Hmm, should have known that
Osborne Tue, 15/01/2019
Hope you can read it on the plate mounted below the recoil starter cover. Otherwise I don't seem to have any model number anywhere apart from the engine crankcase.
gtc Tue, 15/01/2019
After downloading that photo and playing around with brightness and contrast levels I can barely discern B23 punched into the tag.
