Hi finally got it running.
Now that it is running I adjusted the clutches as per the manual. However when it is idling you can hear the main clutch is rattling. Is this normal?
See videos
When the clutch is engaged the rattle ceases
See videos
Probably nothing to worry about as when the pressure is off the plates they an flop about a bit. Just make sure that when it is disengaged the pressure plate on the withdrawal sleeve stays within the basket.
Cheers wristpin. Thanks for confirming all was well
