Briggs and Stratton Engine priming
just went to prime a Briggs and stratton engine to help a Friend with lawn and found the bulb primer will not prime, SO suggested new bulb required, He said the local repairer,s had replaced bulb on primer(little briggs engine with the red primer bulb)Am I missing something or am I right about primer,? any Suggestions Greatly appreciated.
AS Hortimech says, we need
AS Hortimech says, we need the model, type and code numbers from the Briggs. Particularly as there are two types of primer in common use. In addition to cleaning the carb , if it has the corrugated paper air cleaner element you need to pay attention to the positioning and integrity of the gasket that sits between the air cleaner back plate and the carburettor .
My apologies Gentlemen, Think
My apologies Gentlemen, Think it is a pulsa type carb engine numbers are 10D902 0141-B1 02032755.
Assuming the correct primer
Assuming the correct primer bulb (no hole in the top) has been used it looks as though the check valve, pt no 494409 could well be the cause of the problem. If that valve is not seating, instead of a squirt of fuel being pushed into the inlet tract it is possibly just being returned to the tank.
if the mower has few seasons
if the mower has few seasons under it's belt there could also be a build up of debris on the filter screens at the ends of the fuel pick up pipes.
It makes sense to replace the diaphragm and gasket between the carb body and the fuel tank if you remove the carb to clean out the tank and the strainers. Not a dificult task but be careful how you tighten the securing screws don't overdo them.
Thanks for the information
Thanks for the information Gentlemen will give you an up-date when it is "cured"
Saying 'little briggs engine
Saying 'little briggs engine with the red primer bulb' isn't really enough info, it is a bit like saying 'I have problems with a Ford car'
Why did they change the primer bulb ?
Did they clean the carb?
Is the primer bulb damaged, if not, then changing it probably won't help. It sounds like the carb needs a good cleaning, but, without knowing what engine it is, it is hard to be more specific.
