Chain problems
Good day all
I have a particular problem regarding the main drive chain on my mower I am looking for help with.
So I have a Punch 17 inch mower, and shortly after getting the motor running, the chain snapped at the master link. Now my problem is identifying the chain locally in South Africa. I took the chain to our local specialist, and they could not provide me with a master link. So I am aware I will most likely have to import the part, but in order to do so, I will need the right size.
This is the help I need, can someone please give me the correct part number, chain number, master link size, so that I can plcae the order ASAP.
Fairly sure it’s 1/2” x 3
Fairly sure it’s 1/2” x 3/16” . I suggest that you take one of the sprockets to your chain supplier and get them to cut a length to the right link count because they will match the pin size of the connecting link.
