Suffolk Punch MKVII throttle cable
4 posts / 0 new
R111RWD
Last seen: 5 months 3 weeks ago
Hello everyone, I recently got the above mower and have got it up and running today. all was well until the throttle cable snapped...
ive looked online but can't find a replacement, could anyone point me in the right direction?
the manual I got with the mower says the part number is E.7165
Chris G
Chris G's picture
Last seen: 1 month 1 week ago
Always had good service and
Always had good service and parts from Jon Cruse, give them a call yes
https://www.themowercentrehailsham.com/
Hello by the way!
villiers98
Last seen: 2 weeks 3 days ago
If the cable is unobtainable
If the cable is unobtainable with a bit of skill, or a friend who restores old motorcycles you could make one. Use a bike derailleur gear inner cable. Unsolder the throttle lever nipple ( if it's an old cable with brass nipple )and as long as you keep the lengths correct and fit the adjuster first it should work  . Otherwise I have made a new nipple from a brass spindle or screw of correct diameter, drilled and countersunk for the cable and then cut to length. Bit fiddly though
Last seen: 4 hours 52 min ago
Similar cable to that used on
Similar cable to that used on Colts and a variety of other Suffolks. Plenty around.
