Hello..... and Help!
Hello, new member here and straight in with a plea for advice/guidance!
Im currently working on a Qualcast Super Panther and I’m after some replacement cutting reel ball bearings/potentially a new housing with the felt – can any one confirm thats correct and maybe point me in the right direction?
Ive pulled out the broken bearings but it really does seem like id be able to buy new ones and fit them without breaking them straight away.....
I have searched high and low on the Internet and i cant seem to find any advice for this or the replacement housing.
Any help will be greatly appreciated!
Thanks all
I've got plenty of new stock
I've got plenty of new stock if you haven't already got fixed up, use my email address for enquiries.
Thanks both for your reply -…
Thanks both for your reply - Apologies for the delay, ive only just managed to log back in!
I'll reach out to JOn Cruse and see what he has, thank uyou and DJD - Can you please let me know how to get in contact also
TLLS
The parts i need are as…
The parts i need are as follows..
F016 L02 968 - Ball bearing
F016 T40 266 - Seal Ring
F016 A58 249 - Bearing Housing
F016 L02 969 - Washer
If anyone can help, id be over the moon!
Cheers
Hello, I've not been able to…
Hello, I've not been able to log in since the new set up was put in place due to a password problem, but if you haven't got fixed up yet I can look out what I still have for the Panther machines.
PS, I've sent you an email with pics of my parts, but looking again at yours I notice that the bearing carriers are cast iron I think, mine are aluminium so not sure if they'd fit?
Illustrated Parts list for
Illustrated Parts list for Super Panther
https://www.dropbox.com/s/o3eaerxrvqmnr2u/Qualcast%20Super%20Panther000…
I hope that may be of use. The part numbers have probably be changed a couple of times but if you contact Jon Cruse of the Hailsham Mower Centre he will probably be able to recognise them.
It's years since I had one apart but I recollect that the ball races are slightly lighter weight that the similar looking ones used in the more recent machines but Jon will know. The seals look very similar to the ones used until recently on the Electric Punches (Punch EP) but I cant cross reference it to confirm, but again, Jon Cruse is your man.
Edit. If ,in the meantime you want to get the machine up and running, I’d just stick the balls back in with plenty of thick grease and once assembled the cones will hold them in place in the cages.
