Ransomes reelcutter modification
3 posts / 0 new
Mickwhitt
Last seen: 6 days 1 hour ago
Hi all.
I have a ransomes reel cutter cylinder mower and im wondering if I can modify it to become a flail mower for rough cutting.
I believe they did a flail version of the same machine. Is it just a case of making a robust drum on which to mount flail blades and making a steel cover to fully enclose the drum head?
Any thoughts gratefully received,
Thanks Mick
Last seen: 33 min 27 sec ago
At one time it was called the
At one time it was called the Multi-mower with interchangeable reel and rotary ( not flail)  front ends. Over time Ransomes offered a couple of flail mowers but as far as I know they were dedicated machines and not adaptations of the Reel/ Multi-mower.
Mickwhitt
I was wondering if the
I was wondering if the multicutter would have enough power to drive a flail bar.
It should be a pretty easy modification to try, if it doesn't work then I can go back to the cylinder blade.
I've written to a company that supplies flail blades and links for their view on how possible it would be.
Maybe I need to look out for a front end flail for my wheelhorse tractor.
Mick
