Suffolk Super Colt flywheel 'window'
awburton04
I was delighted to recently ressurect a Super Colt, which has been stood for some time. The points and carb needed a good clean.
My intention is to use it regularly at home, so have put some effort into replacing some lost parts (flywheel guard / air filter) and tuning.
After a cut, I noticed some clippings getting through to the flywheel 'window' of which the cover is missing. Is it possible to get a replacement flywheel window? Does anyone have a Suffolk for breaking or parts?
Any help would be appreciated.
Regards,
flywheel window
hi there i presume that it could be a plate with a small self tapping screw or ba screw,
or a plastic cover On more modern versions.
Make up a plate from aluminium cut to cover hole ,
drill fix with small screw self tapping screw should do the trick but check the length.
bobs your uncle cheap fix
