First cut with first restoration project - Greens Zephyr 14”
Thank you for your nice…
Thank you for your nice comments, much appreciated. I did write a bit about the restoration with some photos but doesn’t seem to be added for some reason? I am a new member so really enjoyed working with on the zephyr, great project.
Myself and others will…
Myself and others will certainly enjoy seeing the restoration photos.
As when I have added content, once the hourglass spinny thing loads the picture, click the insert button and photo will appear in the white square box, where the text is, if you do this and see the photo in the white box, then it will post.
What I do is post one photo, them another.
Great stripes Andrew. Well…
Great stripes Andrew. Well impressed. Looking forward to seeing the restoration photos. Cheers. Rob
Finally managed to add a few…
Finally managed to add a few more photos of the restoration. All the parts were stripped down by hand, cleaned then applied two coats of etching primer, two coats of JD green enamel paint then finally two coats of 2k clear.
apart from new replacement cylinder bearings, I managed to keep all and original parts. The cutting cylinder and bed knife were sharpened and set.
Overall I was really pleased with the refurb. I pan doing another  one this winter.
Thank you for looking.
Thank you Rob, mower works…
Thank you Rob, mower works really well. I think I’ve finally managed to load some more photos.
what a lovely restoration!…
what a lovely restoration! and What a wonderful machine the Zephyr is.....
A great credit to you; a proper restoration to the highest possible standard!
