16" Ransoms with a Blackburn Engine various parts needed
I recently purchased a Ransoms Simms and Jefferies lawn mower with a blackburn engine. I want to find some information about it the Reg number is A2303. I need a petrol tank as it is missing and one of the rear cast rollers has been damaged. I am looking to get it working ASAP so any help will be gratefully received.
This last image shows the type of fuel tank that I need.
Hello
Hello
Welcome to the club, the mower you have is often referred to as the Horseshoe Tank model for obvious reasons, yours appears to have the ornate scraper bar/nameplate missing from just behind the rear roller, this would give th Mark number 5, 5A, 6 etc and also the cutting width, you state yours is a 16".
Usually with the Mk number & serial number which you have I can establish a fairly precise date of manufacture, it will probably be from the 1930's.
I may know where there is a Horsehoe Tank, but on a mower that has had a replacement tank fitted alongside, so assume the original leaks!
Where are you located?
I am in Ely Cambridgeshire,
I am in Ely Cambridgeshire, any help identifying it will be good, I can repair a holed tank if necessary. That will be great if you can locate one. I need the N/S rear cast roller also and a grass box. Some photos of what it should look like would be useful also. Thank you for your response
Sorry I have no spares but
but here are some photos of my 16" Mk4, circa late 1920's.
The tank has two caps, petrol on top and oil on the front.
cheers
Alan
That looks a really nice
That looks a really nice machine Alan
Alan can you post a picture
Alan can you post a picture of the scraper plate on the rear of the machine please
Quite a solid looking beast!
I have been informed that it
I have been informed that it is a 16" MK4 from 1928
Scraper Plate
Scraper Plate
This is how the clutch rod
This is how the clutch rod and lever should be arranged.
Your one appears to be upside down.
The last image shows the spring attached to the bolt in the lower foreground.
cheers
Alan
Great images of quality
Great images of quality British engineering at its best. Even the basic design and shape of the grassbox brackets survived right through to the Mastiffs of the 1970s .
I received my new rollers
I received my new rollers today given them the first coat of tung oil. I am still looking for a fuel tank, grass box and a scraper plate if anyone can help please.
A photo of my rollers
I received my new rollers today given them the first coat of rung oil.
Rung oil - what's that.?
Ah, see it now, fat fingers!
Interesting
Precautions
Pure Tung Oil is extracted from nuts and may cause an allergic reaction. Store Pure Tung Oil at a temperature above 5°C. Always replace the lid otherwise the oil can deteriorate. Oily cloths can self-combust. Do not leave impregnated cloths in bundles. Before discarding the cloths lay them flat outside to dry to avoid a fire hazard. If the excess is not removed and the surface becomes sticky, wipe with white spirit to remove the sticky film and allow to dry before continuing.
I forgot to mention I am a
I forgot to mention I am a new member as of today, I also have 3 Atco mowers these are on the back burner until I complete the Ransomes
