Atco missing a cutting cylinder
9 posts / 0 new
Atcough
Last seen: 11 months 5 days ago
My neighbour Bob and myself want to get an Atco working again. It is a 'modern' type with a plastic grassbox, but looks as if it could be useful. The data plate on it states "TYP FO16 309042 579" amongst other info. The machine appears to have been abandoned halfway through an overhaul and is generally sound. Does anyone know which model/year this is, and can anyone help in tracing a cutting cylinder for it?
Last seen: 22 min 56 sec ago
Some decent images will
Some decent images will almost certainly get you an answer.
Atcough
I'll do that asap.
I'll do that asap.
Atcough
Here's the Atco. It seems to be missing a cutting blade, too! The cast side pieces of the cassette are in the grassbox.
gtc
Last seen: 9 hours 10 min ago
I'm not familiar with that
I'm not familiar with that model (it's too recent for me) however from the look of it I'd be inclined to consider it a parts donor for another project, unless you can find one that is missing the engine. Others may disagree.
It's an early Atco Balmoral
It's an early Atco Balmoral with the Suffolk 148cc ,engine.  17 or 20". I was trying to work out the width of cut from the front roller configuration but they all appear to be of the same size and my parts lists for both the 17 and 20" machines show the two outer rollers as a different part number from the inners. Looks to be a 20" , perhaps you will put a tape across it.
Are you sure about, "The data plate on it states "TYP FO16 309042 579" amongst other info." as a 20"  Balmoral is shown as F016 309 642 ?
If it is a 20" machine the cutting cylinder would appear to be part F016 A58 821 with a current price of £161.05 + vat.
Atcough
Thanks very much Wristpin,
Thanks very much Wristpin, good info sent very fast! I can confirm it is FO16 309042 on the plate, it is very clear. Another number is 085000036, if that is any help, and bottom right hand corner of plate is stamped 2000.
Unfortunately I can’t match
Unfortunately I can’t match that number with any of the lists that I have but you definitely have an early Balmoral , either a 17 or 20 inch.
I think that the 08 number is a machine serial number and the 2000 is the year of manufacture. Atco / Qualcast were never the best for parts manuals and updates in the paper era and no longer being a dealer I don't have access to dealer level information on line . The paper lists that I have do not even carry a date of issue.
Atcough
Thanks again, Wristpin. I now
Thanks again, Wristpin. I now know a lot more about the mower, a big step forward. If we can't get anywhere with tracing parts to repair it, I'll probably advertise it for spares.
