Fuelling problem
Atco hd 24 was running fine, then would not start, I took off the float chamber to find the float had fuel on the inside, found the pinhole and made a repair, engine running fine, 2 weeks later no fuel to carb, took out the float it has a small amount of fuel inside again, there is no evidence of any pinholes ect is I cannot get the fuel out. I suspect I can get a new float but I have no engine details other than the make Tecumseh, my local mower shop in France wanted details so he could source one but with no engine details it's a no go. Can anyone help or advise. Thanks in advance. Jb.
I would expect the engine to
I would expect the engine to be an H50 or H60 and the float part number 632019
Hi John I noticed from your
Hi John I noticed from your profile that you are in Bellac - I know the area very well as I have a house nearby in Dompierre-Les-Eglises!
Have you tried the Maximum yard at Mailhac-Sir-Benaize (it is much bigger than the Maximum shop in Bellac) - they always have a good selection of old mowers for sale outside many suitable for parts you might find something with a Techumesh engine there. Most are very cheap.
You probably know the address but just in case the website is: www.associationmaximum.com have bought a lot of good stuff from there over the years including three old mopeds for €20 each two of which are runners!
Also I think the garage at Le Beauvert near Dompierre les Eglises repairs and sells mowers or at least it used to (it is an interesting place too - the workshop has some dusty old classic cars that haven't moved for over a decade - a Simca 1000; Peugeot 504 coupe; Porsche 924 from recollection). They once fixed the year linkage on an old Rover after we drove all the way from Orleans stuck in 3rd gear after a c-clip got dislodged!
Hi Alec,
Hi Alec,
thanks for the info, I will check it out.
best regards.
johnb.
Thanks hortimech, your pt no
Thanks hortimech, your pt no is confirmed by wristpin.
best regards.
johnb.
Thanks for the info.
best regards.
johnb.
I think your engine will be a
I think your engine will be a Tecumseh H50, H60 or HH60, the number is stamped into the airshroud (the thing the starter bolts to) on the top, adjacent to the sparkplug. I also think the partnumber of the float is 632019 (but don't hold me to it)
