Ransomes 14 bottom blade
steveteigh
Thu, 17/09/2015
i am looking for a bottom blade for a Ransomes 14 that i am restoring don't know if anyone can help.
yes i will check shortly
the blade has 5 countersunk
the blade has 5 countersunk screws
the outer screws are 5/8" from edge
screw holes are 3 1/4" apart
Flat or lipped?
Flat or lipped?
Should say that if no one offers one you will be able to get one from Garfitts. If you are an OLC member you may be able to get a bit of discount by placing your order via forum member Richard Jones.
Some dimensions, hole spring
Some dimensions, hole spacing etc will help.
