Ransomes marquis spare parts, carb and exhaust
Petrol_head29
Hi there
Can any one help me find a new exhaust for my ransomes marquis fitted with bsa sloper engine,
My carb is also missing the ajustment screw that fits in the side of the carb
Dan
Thank you, yes it's just
Thank you, yes it's just below where the needle fits into the tube (below throttle cable) to the left hand side.
Exhaust - Think that you can
Exhaust - Think that you can still get the genuine article from either Meetens or Villiers Parts.
Assume that the screw that you need is the throttle slide stop screw that sets the idle position when the slide is closed. Again, Meetens or Villiers Parts. It has a nut on it to lock the setting. I think that it is basically a standard BA sized screw so if neither of the above can help it shouldn't be too much of a problem.
