Scott Bonnar/Morrison parts needed
Hello,
Ive recently acquired a 70's Morrison/Scott Bonnar 14 inch reel mower and im on the hunt for a couple of parts.
Looking at the front of the mower, the left reel bearing housing has at some stage broken due to its modification. The other side is a cast iron unit that will never break.
Would anyone have any idea on where i can pick one up? Anyone have one laying around?
Appreciate any help
Cheers
Alex
wristpin Sun, 22/10/2017
As you are located in the Scott Bonnar homeland I would think that you are in the best position to find one locally. I presume that there’s an eBay au ?  An image will help, particularly with the Morrison / Ransomes connection as old Ransomes used cast bearing carriers.
Alexoc Sun, 22/10/2017
Sorry, my bad. I thought i had uploaded some.
Ive searched all the usual places including the ones posted earlier but with no luck. Worth a shot.
The good side
The broken side.
Difficult to see but is there actually anything functionally wrong with the “ different” bearing carrier? It appears to be just the later fabricated part.
hortimech Mon, 23/10/2017
Any chance of a picture of the entire machine ?
The bearing housings look very similar to Marquis/Auto Certes ones, but a bit hard to tell from a photo without something to scale against, what are the bearings ?
