Suffolk Corporation Drive Cog
14 posts / 0 new
Supergrass
Last seen: 3 months 6 days ago
Hi I am restoring a Suffolk Corporation .Mower has drive to one wheel only, the issue is a worn pinion/pawl pictured,the left is the defective item.any ideas for repair or replacement.
Last seen: 3 hours 7 min ago
In case you are not already
In case you are not already aware the parts are the same as those used on the Squire .
Pinion LH L180
Pinion RH L131
Pawl L378
Try Jon Cruse of the Hailsham Mower Centre
Supergrass
Thanks Wristpin . Also a
Thanks Wristpin . Also a mower called a demon! Could this be an un celebrated class of suffolk mowers?
Yes, but the "similar
Yes, but the "similar configuration" Suffolk 16 and L40 use different pinions and pawls!!
olcadmin
olcadmin's picture
Last seen: 1 hour 52 min ago
Suffolk Demon documents are
OLC Admin
Supergrass
Thanks OLC Admin .Interesting
Thanks OLC Admin .Interesting colour scheme
Supergrass
corporation up date.We have
Corporation up date.We have now got drive to both wheels with parts from a donor mower and pawls from our friend at Hailsham mower centre.Mower bought for parts has an unusual exhaust,(see picture) has any one seen one like this before on a suffolk engine
Not on a Suffolk but used to
Not on a Suffolk but used to see that pattern on Briggs fitted to Merrytillers.
lix
lix's picture
Last seen: 4 months 6 days ago
Hi Supergrass, what are you
Hi Supergrass, what are you thinking of doing with the doner Corporation mower please?
Supergrass
Hi Lix.not sure yet till the
Hi Lix.not sure yet till the project is complete.All ready poached the drive pinions and rollers and may need parts off the clutch .I wont know for sure till its running.Do you have a similar machine?
lix
lix's picture
Thanks for the reply. No, I
Thanks for the reply. No, I have a Suffolk Super Punch but I’m slowly getting hooked on old lawn mowers and this looked a good next project. But it sounds a tad too far gone or stripped for any use. But thanks anyway
Supergrass
The corporation is nearly
The corporation is nearly there,cut an over grown lawn today in a few minutes ,I forget how simple but effective powered side wheel mowers are.The equivalent rotary would require much more horse power ,so there may be a green issue here.The clutch needs a look as it  seems a little loose on the engine side and makes some rattling sounds at idle.It is by no means connoisseurs ,just a working unit with a brush paint Finnish .All been well planning to rally it at MK in may.
Looking good. Interestingly
Looking good. Interestingly one of my operating and maintenance manuals dated July 1957 shows a machine with a different design of handlebars and the optional hammock type grass catcher. I see that yours appears to have the lower catcher mounts on the roller brackets.
Back in the 50s and 60s before rotaries really took hold, powered sidewheel machines were the local authorities'  tool of choice, particularly the Ransomes Antelopes, but  I've often wondered why Suffolk thought it necessary to make the number of variations and sizes that they did.
As you have found, a sharpened and correctly set powered sidewheeler can cover the ground quickly and leave a nice smooth finish. Perhaps not the easiest machine to control but, as you may have found out, letting it do its thing while applying gentle guidance is better than fighting it.
Supergrass
As you say Wristpin,these
As you say Wristpin,these type of mower were popular with the local authorities.We used to use Ransomes  Antelopes in the cemeteries,The nack was just to keep going round and round and if you had to turn sharply bear down on the handels to lift the drive from the wheels.(I was younger and fitter then).I also have a Qualcast Commando in the project pile!
